How to display LAG of several interfaces of switch on the map?
  • Kirin2
    • Jul 2018
    • 28
    First, in this post if I write monitoring I mean display on the map
    Since I've not found any info about monitoring of LAGs of Switches I'd like to ask:
    I have LAG of 2 interfaces in two switches, so it's looks like:
    Switch 1 LAG: Interfaces: 50,51
    Switch 2 LAG: Interfaces: 20,21
    How I can monitor data flow LAG of several interfaces?
    In case of monitoring one interface connection between switches I'm using next script:
    {host:[key].function(0)} - and it works good.
    I've tried to make somethinf like this(one the screen below), but seems it's not good practice.
    Please if you have any mind or advice, I'm open to it.
    Thank you
  • Hernandes Martins
    • Apr 2011
    • 901
    Hi
    Kirin
    You have create a item Calculated(sum) after put on map with the same sintax.
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • Kirin2
      Kirin2 commented
      Thank you!
