Dashboards structure and groups - Dashboard related widgets
  • oskare
    • Dec 2015
    • 14
    I am missing the possibility to easily go between dashboards. I have multiple systems some with 1-3 dashboard view depending on info you want.
    Some focused on problems and events, the visual map. Others more based on graphs and utilization etc.
    To go back to all dashboards and pick the relevant one from a list of 15,30 or more is not an option.
    I have multiple half finished and/or test dashboard currently in that list.
    So solutions....
    1) Have a url widget, can add links to relevant dashboards. Can be used for any url
    This would probably solve all.
    2) Dashboard Navigation, like map navigation. But it would jump to a dashboard (instead of map navigation that controls the map widget)
    3) The dashboard view I´m also interested to introduce a hierarchy, to group all related dashboards.
    4) Perhaps this hierarchy can be implemented into the dashboard, so when a dashboard is viewed it offers a widget to view dashboards on the same branch
    All Dashboards (root)
    |-System-1 (group/branch)
    | |-> dashboard-A
    | | |->Dashboard-X
    | |-> dashboard-B
    | |-> dashboard-C
    | |-> dashboard-1
    | |-> dashboard-2
    | |-> dashboard-3
    A) A widget that allows you to pick a list of dashboards based on a dashboard-group/branch. - This list will link to those dashboards
    This allows most flexibility.
    B) Or a widget that just displays a link to dashboards within the same group/branch as current dashboard. Probbaly would prefer the list will link to the top-most parent branch
