High-class double-layer anti-heat curtain, fabric curtain is composed of a light-blocking fabric curtain and a light-penetrating chiffon fabric inside lớn get gentle light from the outside while ensuring the shielding factor. Get visibility, privacy inside the room.
The outer layer of double-blind curtains is usually sewn in wavy style and opens on both sides, the fabric of the curtain can be selected in plain or patterned pattern, the inner layer of chiffon fabric is sewn in style. A glass or a simple plate is so simple, so charming and charming for the curtain.
- White chiffon fabric is often chosen lớn go with sunscreen fabric curtains, and patterned curtains, the manufacturer also produces the same type of chiffon textures with layers of fabric to match each other.
***Read more : https://refind.com/link/39758135
- Following are some pictures of high-class 2-layer fabric blinds that EveryHome Curtains have constructed for customers
What is the price of 2-layer fabric curtain?
- Conventional fabrics cost about 400,000 to 700,000 Việt Nam Đồng for một meter per layer, finishing construction period from 4-5 days
High quality sunscreen fabric insulated 100%, the price is from 1,300,000 to một,800,000 Việt Nam Đồng for một meter per layer finishing a day, construction period from 4-5 days
Premium curtain imported from Korea, Belgium, Thailand is priced from một,500,000 lớn hai,500,000 VND for một meter of finished goose depending on the color of iron and the material that you choose, the construction time is from 12-18 days, imports should be longer than the fabric is available.
Read more :https://www.deviantart.com/remvaibac...pdate/18100583
