WMI supportq
  • sosher
    • Jun 2006
    • 12
    WMI supportq
    hello all...
    when can we expect support if at all, for wmi ?
    This protocol Exposes many item the can be of use for a NMS.
  • erisan500
    • Aug 2005
    • 285
    WMI is already supported through custom scripts.
    Post an example of a WMI query and we'll show you how to use that as an item in zabbix.
    Greetings
    EriSan
    • sosher
      • Jun 2006
      • 12
      Thanks Erisan , Again
      here is a small script
      --script--
      On Error Resume Next
      strComputer = "."
      Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
      Set colItems = objWMIService.ExecQuery("Select * from Win32_ComputerSystem",,48)
      For Each objItem in colItems
      Wscript.Echo "UserName: " & objItem.UserName
      Next
      -- end of script--
      Its purpose to bring the current logged on user ...
      • erisan500
        • Aug 2005
        • 285
        I modified your script a bit:
        strComputer = "."
        WScript.StdOut.Write objItem.UserName
        Next
        PS. Do not use Wscript.echo as that adds a CR to the output and Zabbix doens't like that.
        Save this script as C:\myscript.vbs
        Now, in your agent config file add a user parameter like:
        UserParameter=myUserName,c:\myscript.vbs
        Then add an item to the right host with key "myUserName"
        Have fun !!
        Greetings
        EriSan
        • dantheman
          • May 2006
          • 209
          You can actually do this without adding a custom parameter to each agent, add an item for that host with the key
          system.run[c:\mycode.vbs]
          And you'll accomplish the same thing.
