I´ve mentioned this before I believe, and commented on posts with similar issues.
The graph widget of Zabbix dashboards are awesome, very flexible and easy to manipulate. But then in other widgets they are missing alot !
Wish they would allow for community developed stuff to be imported. We are all struggling with the similar issues and I imagine and bet there is someone out there willing to solve it !
Examples:
Problems widget:
When I select to show historical it will show all since the beginning of time, I can not select a time range, e.g. last 7 days.
This however works when doing Monitoring-> Problem, I can select a time range. (I need my NOC people to use dashboard, not Zabbix menus)
Why: I have accumulated 3000+ un-ACK problems from my past zabbix days (years worth) when I did not ACK all issues, and I still dont.
But now I have a use-case where I´m monitoring un-Acknowledge problems within a specific host-group ( even if they are resolved) just to keep track.
This cannot be achieved as Zabbix dashbord/widget work today.
Single/stat, item values
There is no widget designed to represent a item or any value and have behavior based on the value.
like single stat in Grafana.
Also would like to add again...
Dashboard hierarchy, to drill down and back up within a specific system using dashboards.
This could be achieved by something simple as a dashboard selection wizard.
But if dashboards can be created as parent/child it would inherit that
Examples:
Problems widget:
