Hello all. Firstly, I don't know if this is the correct category to write this post, so if the mods think it needs to be moved, please do so.
We are taking the step from migrating from nagios to zabbix. Generally, this is a long process, because most people say "same checks, same alerts, as Nagios" so you need to dive into nagios, understand the checks and then implement them onto Zabbix. Also I read quite a lot of forums post relating to this topic, and I found the most interesting this one: https://www.zabbix.com/forum/zabbix-...ecks-in-zabbix
especially the answer from aib, describing the result of a nrpe check:
Since we are limited on time, because a new project is starting and we need the checks, I was thinking doing the following:
1) Use Zabbix itself for all the regular checks(disk, ram, cpu, ping etc.)
2) In place of nrpe plugins, I was thinking using user parameter with nagios plugins, i.e something like
3) Since the returned value will be similar to what I quoted from aib, create a trigger that evaluates this string, and raise an alert if the word "OK" is not in the returned result(or maybe if the word "CRITICAL" is in the string"
4) When this project is done and we have more time, come back to other projects that we are going to migrate, and rewrite the scripts(or write new ones) so the results are more zabbix friendly.
So I was wondering if you could give me some opinions on this thought process, especially on points 2) and 3). I know it's not perfect, but I am thinking this is gonna work. Maybe it will be a little difficult to differentiate between warning and critical alerts, but even if we have 1 trigger(so 1 alert which let's say is always high) is enough.
Sorry for the long post, and I am all open to suggestions.
Thank you!
Example: GPING OK – rtt min/avg/max/mdev = 0.021/0.541/0.598/0.541 ms|time=0.541344ms pl=0% CPU Usage 98%|c[cpu]=98%;80;95;0;100
UserParameter=mail.queue,/usr/lib64/nagios/plugins/check_mailq -w 200 -c 500
Thank you!
