Zabbix SSO Authentication using Jasig CAS!!!!!!!!!!
  • danyll
    • Sep 2020
    We had need for SSO authentication to integrate Zabbix with our other portal "tools". So I decided to implement one. I made changes against zabbix version 2.2.2 and Jasig CAS was used for SSO.
    - User can now choose CAS auth type from Administration -> Authentication
    - CAS PHP library needs to be installed
    When user points to Zabbix login (index.php), it will be redirected to CAS Login and back to zabbix after successful authentication. Logout works too. Everything else is just like using zabbix with HTTP Authentication.
    For developers: If you are interested in about this I can send you patch and others too..
    Thank you..
  • mhodges
    • Mar 2021
    Hello. My very first post.
    Our SA team just upgraded to Zabbix 5.0 (from 2.2) and I'd like the team to integrate it with CAS 5.0. Any information available that I can provide them to help make the request more palatable? I'm hoping for a recipe. They are very capable, but if it I provide enough info to make it look easy, getting the task prioritized will be easier. Thanks for any advice.
