create.sql.gz not present in rpm package rhel7
  • nickwe
    • Sep 2009
    • 13
    Just for your information, the create.sql.gz archive is not present in the https://repo.zabbix.com/zabbix/5.4/r...el7.noarch.rpm RPM so I had to use the one from rhel8.
  • Markku
    • Sep 2018
    • 1784
    https://www.zabbix.com/documentation...es/rhel_centos says:
    Official Zabbix packages are available for:
    RHEL 8, CentOS 8 and Oracle Linux 8
    so I think you did just right: as you are using an OS that doesn't have the official packages published, you need to handle the situation by yourself.
    Markku
    • tuesdh
      • Jun 2021
      Best Paintball Guns Under 200 Reviews june 2021
      Markku
      i'm using an OS device how can i?
      • Atsushi
        • Aug 2013
        • 2028
        Hi tuesdh,
        I don't know which OS device you are using, but Zabbix 5.4 server cannot be built on RHEL 7 using the official package, so prepare an environment that can be used by other OS.
