VMware: Multiple ESXi + vCenter => Same Host names / datastores, etc. errors
  • TDS
    • Jun 2021
    I tried to add multiple Zabbix proxies to monitor external ESXi/vCenter infrastructures. Currently it is not possible if a name ist already taken (e.g. host name or datastore name). So I tried to edit the default templates and added a macro {$VMWARE.PREFIX}. No luck :-(
    Is there a workaround or a solution to "prefix" external proxy data, e.g. in pre-processing / post-processing discovery rules?
  • BiMW
    • Jun 2018
    • 24
    Sorry for my eng. You can use on Discover Vmware Vms FQDN in prototype {#VM.UUID} {#VM.DNS} {#HV.NAME} like a name
    • TDS
      • Jun 2021
      Can you post a screenshot where do you mean to change that?
      • rodrigo.root.rj
        • Jun 2010
        • 26
        Hi TDS, whats up?
        What is your zabbix version, server and agent?
        Do you have a problem to discovery guests in ESX or the ESXi host, the bare metal?
        I have a problem with discovery rule, on 3.5. Maybe is that.
        regards.
        • TDS
          • Jun 2021
          Originally posted by rodrigo.root.rj
          Hi TDS, whats up?
          regards.
          I'm using latest v5.4. The problem is not that I can't discover things. The problem is that I have multiple installations with same datastore names or same VM names.
          Currently I commented out the group prototypes inside template and now it's working.
          • BiMW
            • Jun 2018
            • 24
