Dynamic Perf Counters (A "system.run.perfcounter" for dummies.)
  • LEM
    • Sep 2004
    • 112
    Perf counter under windows can save the deal when using ZABBIX to monitor applications or trying to have some 'deeper' OS details (say the memory used by a given process for example).
    But when you're using Perf Counter, Once the server item declaration done, you still must edit your zabbix_agentd.conf file and restart the ZabbixW32 agent.
    Could it be possible to use an active item like "system.run" but for perf counter? This way, it could be possible to add items on the zabbix server like "system.perfcounter[My Path\To My Perf\Counter]" without having to restart anybody.
    Tia for any answer.
    Cheers,
    LEM
  • peter_field
    • Jun 2006
    • 71
    perf_counter?
    the perf_counter key no good?
    i.e.:
    perf_counter[\PhysicalDisk(_Total)\Current Disk Queue Length]
    perf_counter[\SMTP Server(_Total)\Messages Received Total]
    • vinz
      • Sep 2006
      • 14
      Yes it works !!
      • LEM
        • Sep 2004
        • 112
        i.e.:
        Gotcha! I did not know it yet!
        Thanks a lot: exactly what I was looking for!
        Cheers,
        LEM
