How to export latest Data or graphs values ?
  • makemeasandwich
    • Apr 2015
    • 34
    how can I export latest data or graphs values? All I see is plain text and that would mean I need to copy paste everything into for example excel
  • BDiE8VNy
    • Apr 2010
    • 680
    You can export item history either via the Zabbix API or via SQL by accessing the Zabbix database directly.
    You might possibly also be interested in ZBXNEXT-1723
    If non of these options appear sufficient to you, then consider to create an appropriate feature request - if non of such exists already, of course.
    • sancho
      • Mar 2015
      • 301
      Although this is old, I'm sharing another way to export the results of Lastest Data to CSV.
      Using this module by the great aigars.kadikis https://blog.zabbix.com/generating-z...-module/24369/
      You can use the following query by changing itemname and hostgroup to the item you want to retrieve and the host group in which to search for this item.
      SELECT h.name AS host,
             i.name AS item,
             ht.value AS valor,
             FROM_UNIXTIME(ht.clock) AS fecha
      FROM items i
      JOIN hosts h ON i.hostid = h.hostid
      JOIN history_text ht ON ht.itemid = i.itemid
      JOIN hosts_groups hg ON hg.hostid = h.hostid
      JOIN hstgrp g ON g.groupid = hg.groupid
      WHERE i.name = 'Itemname'
        AND i.status = 0
        AND i.flags IN (0,4)
        AND g.name = 'Hostgroup'
        AND ht.clock = (
            SELECT MAX(hh.clock)
            FROM history_text hh
            WHERE hh.itemid = i.itemid
      ORDER BY h.name;
      For example, if we search for the "Free swap space" item on hosts belonging to the "Windows Servers" host group, the query would be as follows:
             i.name AS item,
             ht.value AS valor,
      FROM items i
      WHERE i.name = 'Free swap space'
        AND i.status = 0
        AND g.name = 'Windows Servers'
        AND ht.clock = (
      ORDER BY h.name;
      Zabbix version tested: 7.4
      I hope it is useful to someone.
      • PavelZ
        • Dec 2024
        • 172
        Many people use Grafana together with Zabbix. And this program has export on any graph, apparently.
        • sancho
          sancho commented
          Yes,
          Grafana is a way to export information to CSV. The one I've posted is another way to export the same information we get in Latest Data from Zabbix to CSV. Greetings.
