in-graph triggers not shown when using context-specific macros from templates
  • user185953
    • Aug 2021
    I really like that graphs also show the relevant triggers - like .
    They are especially useful, because in the graph "100M" means 100*1000*1000, but in the user macro which sets the trigger "100M" means 100*1024*1024.
    Displaying the trigger levels in the graph allows me to verify that I have done the awkward 1024-to-1000 math correctly.
    EDIT: Wrong. That was not the problem at all.
    The actual problem was, that I changed the trigger to
    ({template-common:level[{#SNAME}].last()} > {$MAXLEVEL:"{#SNAME}"}) and ({template-common:isDisabled[{#SNAME}].last()}=0)
    Removing the other item does not help:
    But the original version with no parentneses works fine:
    I'd like to report that this feature does not work when there are multiple levels of templates and/or context-specific macros in the templates.
    Concretely, let's assume the configuration is hostXY > template-hostgroupX > template-common.
    "template-common" defines all the items, triggers, graphs and LLD prototypes.
    "template-hostgroupX" sets macro values for groups of hosts to avoid copy-pasting errors.
    "hostXY" just links the template-hostgroupX.
    template-common macro: {$MAXLEVEL} = 0;
    template-common trigger prototype: "{template-common:level[{#SNAME}].last()} > {$MAXLEVEL:"{#SNAME}"}"
    template-common graph prototype for "template-common:level[{#SNAME}]"
    template-hostgroup1: {$MAXLEVEL:tank1} = 30;
    This should reproduce my problem of trigger levels not showing.
    Everything works correctly only when I copy the macros directly to the hosts, unlink template-hosgroupX, link template-common.
    Last edited by user185953; 13-08-2021, 10:15. Reason: Clarify more which expression works and which doesn't
    • 4993
    Bug reporting is better to do in
