Installing Zabbix Agent on Live System
  • rewilliamscpro
    • Dec 2015
    All, I am in the process of installing the zabbix-agent to all of my production servers. I have installed zabbix-agents to all of our testing servers and things are working smoothly. I don't believe it will cause any impact but do you think that it is a bad ideal to install zabbix-agent during a maintenance period without bringing down app and database?
    Any Feedback is appreciated.
    Thanks,
  • unficyp
    • Dec 2014
    • 27
    Installing the agent shouldn't affect running services, i did that all the time in our network(s), no negative impact. Is it bad practice or a bad idea ? Depends on you company IT rules i would say.
    • rewilliamscpro
      • Dec 2015
      Thanks for the reply, I didn't think it would affect but i'm just trying to be extra careful. I reached out to some other colleagues and thaey said the same thing.
      Thanks for your response.
      • kloczek
        • Jun 2006
        • 1771
        Thanks,
        Zabbix agent is not using any DB backend.
