"kubernetes cluster state by http" template does not work.
  • inyoungmin
    • May 2022
    To check the Kubernetes monitoring function, I installed Zabbix 6.0.4 and deployed Helm Chart.
    Most of the templates worked successfully, but the metric items in the templates below do not work.
    Problem Template: Kubernetes cluster state by HTTP
    Issue Item: Kubernetes cluster state by HTTP: Kubernetes: Get state metrics
    Executing the metric item fails and the following message appears.
    - "1153:20220511:124607.550 [ Kubernetes ] ERROR: Error: cannot get URL: Timeout was reached."
    Attach related screens.
    Can you help me solve the problem?
Name:	스크린샷 2022-05-11 오후 9.55.13.png
Name:	스크린샷 2022-05-11 오후 9.57.07.png
Name:	스크린샷 2022-05-11 오후 9.57.21.png
  • bryanquadrado
    • Dec 2023
    Has anyone found a solution? I'm facing the same problem, and my configuration is very similar. I'm not sure what to do next.
    • bryanquadrado
      • Dec 2023
      The issue I encountered was due to the service for the state endpoint being different from the default. After I modified the variable {$KUBE.STATE.ENDPOINT.NAME}, it started working properly.​
