[Suggestion] Default SAML authentication
  • tsluszniak
    • May 2022
    it would be nice to have the SAML as one of the default authentication methods. In our case, it's the only one we are using.
    • 4993
    You do understand, that there are many people besides you, who are not in slightest interested in SAML.. ?
    • tsluszniak
      • May 2022
      So what? It's just a suggestion. Maybe you're not interested..?
        • 4993
        Don't take it personally, but this is just very selfish suggestion... Just because You need it, lets make it default? Come on. You can do those 3 clicks to configure it. Its not something you are doing many times...
        • tsluszniak
          • May 2022
          Maybe, but there are 3 authentication methods to be configured: Internal (HTTP settings), LDAP, and SAML. Why only Internal and LDAP should be available to be default options? This suggestion is to make it more consistent.
          • GilchristT
            • Oct 2022
            Plus one for this suggestion.
            To be clear, neither I nor the OP are suggesting it should be THE default login, just that there is an option to set it as the default logon
            • tsluszniak
              • May 2022
              Any chance to add SAML as one of the Default authentication methods?
              • gofree
                • Dec 2017
                • 400
                per se i'm not against on "why not ground" but I also respect that there are really higher priorities areas where Zabbix can be improved ( everybody has its own ) https://support.zabbix.com/browse/ZBXNEXT-6934. And finally in my opinion there is a better place for such requests even it can be funded by your company for example. Still I think this could be pretty small in dev hours, on the other side there are thousands small things
