Is it possible to have severals zabbix servers active with high availability ?
  • Clayzes
    • May 2022
    • 29
    I'm trying to deploy zabbix on my network and I would to use 2 Zabbix servers as a cluster.
    1 server on my local network without any internet access , and an other one which can access to other devices on the cloud.
    I want them to use the same database and frontend , but is it possible ?
    I found documentation about High availability but it says : "Only one node can be active (working) at a time."
    So maybe it's not possible https://www.zabbix.com/documentation...epts/server/ha
    Thank you
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 152
    The documentation is right, it's not possible.
    • Clayzes
      • May 2022
      • 29
      ok , thank you for your answer.
      Do you think I should use a proxy server ?
      I'm student trying to improve in cybersecurity so i'm trying to create a network architecture less vulnerable as possible
      • Glencoe
        Zabbix developer
        • Oct 2019
        • 152
        Proxies is no full substitute to an HA solution but it will certainly increase a fault tolerance of the entire system because: (1) if a proxy fails only a fraction of your data is lost, and (2) if a server fails (be at an HA cluster or not) you're still collecting your data.
