Monitoring E1 connection
  • bisana
    • Jul 2005
    • 87
    Hi All,
    Was trying to see how could Zabbix be used to monitor the BTU (HUAWEI BTS 360) , it does not have IP.
    Any idea how could we use Zabbix for monitoring BTS unit which do not have IP
    Guidance and advice requested
    Joseph John
  • Colttt
    • Mar 2009
    • 878
    ok, you want to monitor Bluetooth-speaker correct?
    what do you want to monitor?
    Debian-User
    Sorry for my bad english
    • bisana
      • Jul 2005
      • 87
      want to monitor the status, whether it is connected or not
      Hi Colttt,
      Thanks for the reply,
      Sorry I should have mentioned earlier what to monitor, I want only now to monitor the status of the BTS, whether it is up or down.
      This BTS from Hawauei has its own monitoring system known as i2000, and the customer is getting results from there. What I want to do is to show a demo that it is possible for getting information from BTS unit using Zabbix, even a simple status monitoring for the links will suffice and this level.
      The Zabbix project is for demo purpose, I want to show that monitoring of BTS Is possible by Zabbix
      Joseph John
