Forum not availabe from corporate Network using Secure Browser
  • MADxHAWK
    • Apr 2011
    • 41
    just for information.
    the forum is not available in a corporate network using HP Enterprise Secure Browser / HP Wolf Security.
    The website get stuck during the security check
    Checking if the site connection is secure
    www.zabbix.com needs to review the security of your connection before proceeding. zz0.ywuotdawxhpzz
    The zabbix.com domain itself is listed as trusted domain.
  • Answer selected by vitalijs.m at 08-09-2022, 08:54.
    Alex Mit
    • Sep 2022
    Hello MADxHAWK,
    Zabbix allows connection to the forum only from trusted browsers included in the whitelist of Cloudflare. It helps us to avoid DDoS/DoS attacks.
    Here is the explanation of how Cloudflare Browser Integrity Check works - https://support.cloudflare.com/hc/en...ntegrity-Check
    I recommend contacting the Cloudflare support team and asking them to include HP Secure Browser in the whitelist they support.
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Would be nice to get bit more details, what exactly is that seems a trouble to them. :-) A screenshot, anything would be nice.
      • MADxHAWK
        • Apr 2011
        • 41
        Hello dimir,
        After opening zabbix.com/forum the protection of cloudflare appears and keep running, while the Ray ID keeps changing every few seconds.
        It seems the check wont be finished so you could proceed to the forum itself.
        Companies like mine using secure browsing like HP Sure Click Secure Browser that opens unknown / unapproved Websites in a Micro-VM environment.
        The zabbix Website and subpages itself is approved by our network security team.
        I suspect the Micro-VM to somehow block some of the Checks and thats why the Check keeps to restart over and over again.
        • Alex Mit
          • Sep 2022
          Hello MADxHAWK,
          • MADxHAWK
            • Apr 2011
            • 41
            Hello Alex Mit , thank you for this information. i will try contact them
