Macro(ize) period, trends, history period
  • tserreyn
    • Jun 2012
    • 26
    OK so I an using 6.2.3 currently and was wondering if it is possible to use a macro to define the period, history and trend timeframes via macro.
    Something like the following:
    on a customer template
    defperiod=5m
    defhistory=90d
    deftrends=365d
    on a nonpaying customer template
    defperiod=1h
    defhistry=1d
    deftrens=10d
    on an internal template
    defperiod=1m
    defhistory=365d
    deftrends=1000d
    then we only keep the data around that is important?
    Is this possible? Can I just put a macro into the period field?
    • 4993
    https://www.zabbix.com/documentation...tem-prototypes
    yes, it is possible.
