Am I missing something or I can't just monitor an HTTPs scenario using IP?
With HTTP you can place the IP in the URL and pass an host header.
With https, you get a SSL connect error, regardless of the "SSL verify host" setting.
I saw a ZBX-next about manually setting the IP but it was closed when header-passing was implemented.
I believe the manual passing of settings or selecting IP address (along perhaps with other CURL-options) would be a MAJOR improvement to WebScenarios to test same service on pools of origin servers.
