Prioritise queue
  • netod
    • Nov 2006
    • 36
    Prioritise queue
    Hi guys,
    was wondering if there was any way to prioritise the queue? When you add a new item+trigger. it takes forever for the item to be updated. I was wondering if there was any plans to add priority to the queue so that some items get polled before others...
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Note that if you add an active check it takes some time (5 minutes) for agent to understand that there is a new item for monitoring. For all other types of items, if there are no performance problems, ZBABIX should react immediately.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • netod
      • Nov 2006
      • 36
      Are there plans to add queue manipulation functionality? For example, if you had long intervals between polls you may wish to force a poll in order to test that everything is working fine? You may also wish to flush the queue for one reason or another.
