Top Hosts widget with item pattern
  • markfree
    • Apr 2019
    • 875
    Using Zabbix 6.2, I have some Dashboards that use the Top Hosts widget, which displays items according to the item data.
    Currently, the item data I'm able to input is only for an specific item. I'm not able to use item patterns for the item field.
    If I try to use a wildcard, it fails to find the item data.
    The item pattern feature is available with Graph widgets, though.
    Click image for larger version  Name:	image.png Views:	0 Size:	61.4 KB ID:	461970​
    Without that feature, when using items that have slightly different names, the widget does not display all the data.
    Does anyone else would benefit from the item pattern feature?
  • markfree
    • Apr 2019
    • 875
    I've created a feature request ZBXNEXT-8368 for this topic.
    If anyone wishes this feature to be available, please upvote the request.
