How does on monitor NetApp Flex volumes.
  • wooway
    • Mar 2023
    I am currently using the 3rd party template "SNMP NetApp cDot For Netapp Ontape 9.5 and later.Discovery" However, I don't see anything for monitoring flex volumes. I try to snmpwalk the filer and I'm unable to locate the volume name. Has anyone worked with this?​
  • michael.weber
    • Nov 2015
    • 121
    Currently there is a "official" template that uses the "new" API:
    I switched to this one. Give it a try, flex volumes should be monitored by this as we are using only flexvolumes but flexgroups need to be tested. Perhaps I find some time next week.
    • wooway
      wooway commented
      Were you able to test the flexgroups out?
  • michael.weber
    • Nov 2015
    • 121
    https://www.zabbix.com/integrations/..._aff_a700_http
    It is working with the template Netapp monitoring and integration with Zabbix​ . We are currently using Ontap 9.11.1P3.
    Best Regards! Click image for larger version
ID:	462735 Click image for larger version
