Monitor>Host>Configuration - changed since 5.4
  • zabbix99
    • Jan 2023
    Hi, we upgraded from 5.4 a few months back and I'm sure there's been a change in the UI/flow where you're now not able to jump to the item config page from Monitor>Host>Configure. Can this be added in a future release please? I'd often jump into monitor menu to check out a host then need to check an item or trigger so click "configure" to see a limited configure modal.
    Appreciate you're time to review this
    Kind regards,
    Kev
  • Atsushi
    • Aug 2013
    • 2028
    What version of Zabbix are you using? For Zabbix 6.4, display the list of hosts in "Monitoring" -> "Hosts". Then, from the menu displayed by clicking the name of the host you want to change, you can make various settings such as the host, items, and triggers.
    • zabbix99
      • Jan 2023
      Hi Atsushi,
      Version is 6.2.8. When clicking Monitoring>Hosts then clicking the host we get a popup menu and have options to "configure" option under "Web" but the window that follows on doesn't have any further options for host items/trigger configuration Click image for larger version
      Clicking "configure" gets this pop up menu
        • 4993
        That's how it is nowadays... latest data is for viewing data and if you want to configure, you should go to Configuration-> Hosts. Or just search for host and you get a page where all the links are present, latest data and options for items listing etc...
        You can get to item config also if you open latest data and click on item name and from there configuration..
        You get used to it..
