Do not upgrade to Zabbix 6.0.15
  • Atsushi
    • Aug 2013
    • 2028
    I noticed a report from a Japanese user and tried it, and there is a problem that the value of the item cannot be obtained in 6.0.15.
    I've also posted a bug report.
  • BiMW
    • Jun 2018
    • 24
    to late
    • Spoonman
      • Aug 2013
      • 45
      Too late indeed, I'm already running 6.0.15......
      • max_bz
        • Mar 2023
        • 17
        You can downgrade back to 6.0.14
        Changing minor versions is possible without compatibility problems, as far as I know.
        sudo yum -y downgrade zabbix-*[6.0.14-release1.el9]
        This solves the problem, the metrics reappear.
        The error occurs in metrics that use the "changes per second" preprocessing rule.
        I think version 6.0.16 with a fix for this bug will be quite soon.​
        • jekahawk
          jekahawk commented
          On Ubuntu apt-cache does not allow you to rollback to a previous version of the package. There are no previous packages in the cache. Or is there any solution for it in Ubuntu?
      • markuman
        • Mar 2023
        Theoretically it would be possible with `sudo apt-get install zabbix-server-mysql=6.0.14`, but unfortunately, their repo software contains only the latest version: See https://support.zabbix.com/browse/ZBX-19947​
        Theoretically you can do
        sudo apt download --print-uris zabbix-server-mysql # change the minor version and wget it
        sudo systemctl stop zabbix-server
        sudo apt remove zabbix-server-mysql
        sudo dpkg -i zabbix-server-mysql_6.0.14-1+ubuntu22.04_arm64.debzabbix-server-mysql_6.0.14
        sudo systemctl start zabbix-server
        • nikira
          • Jul 2021
          Also the interface speed monitoring in 6.0.15 doesn't work, even after I clean install zabbix 6.0.15 doesn't monitor its own interfaces either.
          • lizza
            • Apr 2023
            You can downgrade back to 6.0.14. Changing minor versions is possible without compatibility problems.​
            • georgeMyName
              • Oct 2020
              • 13
              HI, how can I downgrade on Debian please? I am also affected. Do we know when 6.0.16 will be released?thx
              • georgeMyName
                • Oct 2020
                • 13
                I will reply to my post . I was able to downgrade by running:
                wget http://repo.zabbix.com/zabbix/6.0/de...an11_amd64.deb
                dpkg -i zabbix-server-mysql_6.0.14-1+debian11_amd64.deb
                apt update
                systemctl restart zabbix-server​
                When is planned release of 6.0.16 ?
                • Atsushi
                  • Aug 2013
                  • 2028
                  6.0.16 has been released. Please try to see if that solves the problem.
                  Explore the list of new features and improvements for every Zabbix release.
                  • ncrandell
                    • Apr 2023
                    Upgrading to 6.0.16 solved this issue for me.
                    • georgeMyName
                      • Oct 2020
                      • 13
                      Also, issue reslved by new version.
