Brocade FC by SNMP wrong OIDs for Bits Send and Received
  • MADxHAWK
    • Apr 2011
    • 41
    i have noticed the OID for net.if.in and net.if.out seemst to be wrong in the template and i got no data at all for those values while every other values were monitored fine. (Brocade G620)
    According to https://oidref.com/1.3.6.1.2.1.2.2.1
    the correct OIDs are
    net.if.in = 1.3.6.1.2.1.2.2.1.10
    net.if.out = 1.3.6.1.2.1.2.2.1.16
    after i changed
    SNMP OID for Bits Received to 1.3.6.1.2.1.2.2.1.10.{#SNMPINDEX}
    and
    SNMP OID for Bits Send to 1.3.6.1.2.1.2.2.1.16.{#SNMPINDEX}
    in the templatefile the template works just fine and all values are monitored as expexcted
    Maybe it helps somone.
  • Steven09
    • Jul 2023
    Thanks for help to solve similar problems with monitoring network interfaces on our Brocade G620 switches using Zabbix. By correcting the SNMP OIDs to the accurate ones for "net.if.in" and "net.if.out," Zabbix will be able to retrieve the correct data and monitor the network interface traffic as expected.
