VMWARE active agent not reporting data
  • etacosn
    • Jul 2023
    Hello guys,
    my zabbix server is not able to get datas from my zabbix active agent configuration
    here is my setup
    i have my zabbix 6.4 server with some proxies.
    then i have integrated my vcenter to zabbix server using ProxyA
    let say also i have customize my zabbix vmware template as bellow on host_prototypes
    #Zabbix template for vmware customization
    host_prototypes:
                  uuid: 051a1469d4d045cbbf818fcc843a352e
                  [B]host: '{#HV.NAME}'[/B]
                  group_links:
                      group:
                  group_prototypes:
                  templates:
                      name: 'VMware Hypervisor'
                  macros:
                      macro: '{$VMWARE.HV.UUID}'
                      value: '{#HV.UUID}'
                      description: 'UUID of hypervisor.'
                  custom_interfaces: 'YES'
                  interfaces:
                      ip: '{#HV.IP}'
              uuid: 9fd559f4e88c4677a1b874634dd686f5
              name: 'Discover VMware VMs'
              type: SIMPLE
              key: 'vmware.vm.discovery[{$VMWARE.URL}]'
              delay: 1h
              username: '{$VMWARE.USERNAME}'
              password: '{$VMWARE.PASSWORD}'
              description: 'Discovery of guest virtual machines.'
              host_prototypes:
                  uuid: 23b9ae9d6f33414880db1cb107115810
                  [B]host: '{#VM.NAME}'[/B]
                  group_links:
                      group:
                  group_prototypes:
                  templates:
                  macros:
                      macro: '{$VMWARE.VM.UUID}'
                      value: '{#VM.UUID}'
                      description: 'UUID of guest virtual machine.'
                  interfaces:
                      ip: '{#VM.IP}'​
    the main change is about the host value. for our concern here i made zabbix to see my VMs name as it host id instead of #VM.UUID (the vm id from vmware) as it is on the default configuration
    then, when zabbix is discovering my hosts, it setup the real hostname of my vms as zabbix host id
    the discovery has gone verry well, and everything is ok. the VMs came with ProxyA as assigned proxy, which is also good for me
    now i want to connect the active agent configured on the VM to my zabbix throug the ProxyA
    i made my zabbix configuration as bellow
    #ActiveAgent config file
    Server=ProxyA,Zabbix-Server
    ​ServerActive=ProxyA,Zabbix-Server
    ​#Hostname=
    this configuration ensure that the host will contact zabbix using it own hostname which is already known by zabbix as already discovered whith vmware
    no change on my proxy configuration
    but no data is repported by zabbix
    i have configured an auto registration for activeagent machine which run well for VMs as the VMs joined autoregister machine groupe.
    but i still not able to get system level data from that agent
    on the agent log file, i have bellow error
    [101] no active checks on server [ProxyA:10051]: host [HMSNSPSUP254154AP] not found
    on the proxy log, i have this as error:
    cannot send list of active checks to "172.16.254.154": host [HMSNSPSUP254154AP] not found
    Can anyone help pls.
    Sorry to be so long
