Please add debian bookworm repo for zabbix-agent2 plugins
  • czechsys
    • Aug 2020
    We have zabbix server packages for debian 12.
    But somebody forgot that repository https://repo.zabbix.com/zabbix-agent.../debian/dists/ is missing bookworm still.
    It's breaking our ansible deployment (fixable, but ...)
    Thanks.
  • Answer selected by czechsys at 10-08-2023, 11:12.
    czechsys
    • Aug 2020
    Plugins was moved to main zabbix repository some time ago based on https://support.zabbix.com/browse/ZBXNEXT-8441.
    For example: http://repo.zabbix.com/zabbix/6.0/de...an12_amd64.deb
    • Steven09
      • Jul 2023
      You can check if there are any other community-maintained repositories that might have the Zabbix agent package for Debian 12 "Bookworm." However, be cautious when using third-party repositories, as they may not have the same level of security and reliability as the official ones. myfedloan
      • Markku
        • Sep 2018
        • 1784
        Thanks.
        If you think this is a real problem with the Zabbix repository (I don't have any idea about agent2-plugins), you should open an issue in https://support.zabbix.com/.
        Markku
        • mf2hd
          • Aug 2023
          Thanks.
          Same missing dist issue causing problems here.
          Can't install community zabbix agent ansible role on a proxmox host because of the missing bookworm dist in repo.
          TASK [community.zabbix.zabbix_agent : Debian | Install gpg key] ************************************************** ************************************************** ************************************************** ************************************************** ************************************************** ***
          task path: xxx/collections/ansible_collections/community/zabbix/roles/zabbix_agent/tasks/Debian.yml:26
          fatal: [pve1.tld.com]: FAILED! =>
          msg: |-
          The task includes an option with an undefined variable. The error was: 'dict object' has no attribute 'bookworm'
          The error appears to be in 'xxx/collections/ansible_collections/community/zabbix/roles/zabbix_agent/tasks/Debian.yml': line 26, column 3, but may
          be elsewhere in the file depending on the exact syntax problem.
          The offending line appears to be:
          - name: "Debian | Install gpg key"
          ^ here
          ​I guess that there are several workarounds, but maybe bookworm would be added anyway in some point?
          • czechsys
            • Aug 2020
