Ive noticed that i get a lot of false alerts from Cisco Temperature monitoring since there is only one threshold used for every temp sensor
for example on an C9000 with IOSX there are multiple sensors with different treshohlds
or another Catalyst C9xxxx series switch where many temperatures during usual conditions are above the fixed 50°C thereshold.
I would suggest to to use the temperatur (oid iso.3.6.1.4.1.9.9.13.1.3.1.3.xxx) for monitoring and the oid iso.3.6.1.4.1.9.9.13.1.3.1.6.xxx which is the current state (1 is OK) for the trigger instead of using a fixed threshold for.
Temperature:
Module Sensor MajorThresh MinorThres CurTemp Status
(Celsius) (Celsius) (Celsius)
1 FRONT 80 70 24 Ok
1 BACK 70 42 24 Ok
1 CPU 90 80 32 Ok
1 Heavenly 110 90 49 Ok
Slot Sensor Current State Reading Threshold(Minor,Major,Critical,Shutdown) ---------- -------------- --------------- ------------ --------------------------------------- Chassis1-R0 Temp: Coretemp Normal 46 Celsius (107,117,123,125)(Celsius) Chassis1-R0 Temp: UADP Normal 52 Celsius (107,117,123,125)(Celsius) Chassis1-R0 Temp: Outlet Normal 37 Celsius (63 ,73 ,103,105)(Celsius) Chassis1-R0 Temp: Inlet Normal 28 Celsius (56 ,66 ,96 ,98 )(Celsius) Chassis2-R0 Temp: Coretemp Normal 47 Celsius (107,117,123,125)(Celsius) Chassis2-R0 Temp: UADP Normal 62 Celsius (107,117,123,125)(Celsius)
