Allow an item value selection for column Min and Max fields in the Top Hosts widget
  • _Andrey
    • Jul 2013
    • 27
    Hi everyone.
    To make long story short let's see on the following example: I have a group of file servers for witch the most important metrics is, of course, are disk space metrics. Let's assume I do have 2 of them monitored: "Total on /" and "Used on /" and I want to display it by using bar or indicators which is nice and pretty but kinda useless - and I'll explain why below. So I configure these columns in my newly added widget and there is a question: what should I enter into Min and Max fields? It will be quite non-informative to use some static value in case if disk size is differs between servers in this group, which is almost always are... Or I can leave these fields blank and values will be calculated automatically... but based on max value in of the same item among whole group which is non-informative too. This is a quite frustrating situation without exit, as for me...
    But if only I could use an item value from "Total on /" metric then my indicator would showed me correct amount of used space and it would be great!
    • 4993
    Using (gathering, calculating) percentages would eliminate this. Max would always be 100%
    • _Andrey
      • Jul 2013
      • 27
      Thanks for the proposal, appreciate that
      Although that It cost me an additional database space for adding additional item check (which is percentage disk space check) I think the result looks acceptable.
      But also the fact is that it's not solely a problem - but still a new feature request too. The Top Hosts widget very idea looks promising (if I got it right) and I still think that such function as relative min/max will be very useful.
        • 4993
        https://support.zabbix.com/browse/ZBXNEXT is the place to make proposals for development.
