Out of box templates curiosity
  • sdvidal
    • Aug 2021
    I have noticed version 6 does not have nested templates anymore, as it was in version 5.
    I would like to know if this was a planned decision and where I can find more information about this approach.
    Thank you!
  • Answer selected by sdvidal at 20-03-2024, 20:38.
    cyber
    • 4993
    Understood... I cannot pinpoint it right now... There are some reasons, why it may be good, mentioned here https://support.zabbix.com/browse/ZBXNEXT-8087 (which is about removing nesting at all, they did it in 6.4rc1, but removed it in 6.4rc2).
    But simplification of OOB templates seems to be main reason for now...
      • 4993
      I think oob templates were just rebuilt like that to reduce complexity.. but you can still link templates to each other...
      • sdvidal
        • Aug 2021
        yes, I have same opinion and I know what I can do. I just would like to understand better about this decision : for instance, is this change listed at release notes ? which one ?
        Or it was a decision to reduce "Templator" tool complexity work ?
        I am working on an upgrade, from 5 to 6, and my option was to use a clean install, which means I am inputting all hosts , reviewing templates, etc. I notice this change and I would like more information, thats all.
        regards,
          • 4993
          • sdvidal
            • Aug 2021
            Hi Cyber,
            that was exactly what I was looking for!
            That topic was a great discussion: I prefer nested approach, but my environment is not big and I am working with zabbix about last 3years, I have a lot to learn about api e advanced stuff, for instance.
            But I could feel some pains like template interchanging : the thing about id value must be fixed/addressed as soon as possible.
            Well, thank you for time.
            best regards,
