Zabbix web scenario timeout issue
  • Kastriot Ahmeti
    • Mar 2024
    Hey guys,
    I am new here so i dont know if this is the correct place to ask this, but i will give it a try anyways.
    I have my zabbix setup in a Kubernetes cluster using "Helm Zabbix". Now zabbix works perfectly however one of my most important uses are the Web Scenarios. I have configured all my web scenarios to have a single step (in most cases), and the timeout for that step is 2 min. However i have noticed a trend over the last few months, that the timeout keeps increasing without a noticeable pattern. Even though zabbix should check each web scenario (220 in total) every 2 minutes, most of the time it does not go back to check for 10-15 minutes, sometimes even 20+. This results in inaccurate monitoring logs, therefore i dont have a clear picture of how long for example a web scenario was really out for.
    Would appreciate any help i can get.
    • 4993
    Timeout 2 minutes? What kind of webpages take 2 minutes to timeout? Sitting behind some 14.4k modem? Even there it should work faster than 2m per webpage..
    There was just recently similar topic... reason was just too few http pollers... default is 1, I think... It just cannot cope with amount of work it needs to do... If you would have Zabbix server monitoring, it probably would also tell you that "http pollers are running on 100% " or similar...
