Is it possible to monitoring all certificates expired on fortigates using API?
  • Aliensec
    • Apr 2023
    Dear Community,
    I need to collect an ITEMs on Zabbix the All certificates but it is not possible using SNMP.
    I can collect and monitoring if all certificates was expires and expired using API connection.
    Could anyone help me with how I can do this via API?
    Regards,
    • 4993
    It is more of the question about Fortigate API... you shoudl probably construct a API call, that returns all the needed values and then create a template on top of it... http item -> discovery of all certs (prototypes for) and collecting data about their expiry dates. And then adding triggers to warn you about running out of time ...
    • Aliensec
      • Apr 2023
      I was able to collect the certificate data but it is not creating the ITEMs from the certificates when I place the ITEM prototype in discovery. I have not identified a way to successfully create these ITEMS. Could you guide me? Do I use the Dependent ITEM? Json scripts?
