First weekday in the calendar of maintenance
  • lknsfos
    • Apr 2018
    Hi! When using a calendar to create an maintenance period first day is always Monday. Even using locale en_US, or changed locale en_GB to first_weekday 1.
    Is there a method to change this?
    Zabbix 6.0, Zabbix 7.0
  • moooola
    • Jul 2024
    • 33
    Hello lknsfos
    In my environment, I edit around line 507 of /usr/share/zabbix/js/class.calendar.js.
    var prev_days = this.cdt.getDay() - 1; -> var prev_days = this.cdt.getDay();
    And for details on other changes, please see the code on the reference site.
    The URL I used as reference https://qiita.com/130cmWolf/items/d517b8a662e4d08bbe62
    *Note: This is a Japanese site.
    • melvas66
      • Jul 2024
      In Zabbix, the default start of the week is usually set to Monday, which can be adjusted through user profile settings. To change the first day of the week, go to your user profile and look for the "Locale" settings where you can set your preferred first weekday. Additionally, if you have access, check the global configuration settings for any locale options that might influence the calendar. In some cases, adjusting the source code or configuration files may be necessary if these options don't work. This applies to both Zabbix 6.0 and 7.0. Let me know if you need further help!
      • Markku
        Markku commented
        AI hallusination? There is no preferred first weekday setting in user profile.
        Markku
