Zabbix - Nutanix Monitoring
  • antonius genta
    • Aug 2024
    Hello Everyone,
    Does anyone have a Nutanix template for AOS Version 6.5? I tried to configure using the template that I downloaded from GitHub, which no longer supports the version of Nutanix that I am using. We carried out testing with the snmpwalk command successfully. However, Zabbix failed to collect all the sensors on Nutanix,
  • Yerbabie
    • May 2025
    Yep, can confirm this is a problem.
    I have the same issue the current scipts which have been test on 6.5.5.7 fail to work, they are just not ro-bust enough or they need to expand their testing, we run 6.5.6.5 which fails.
    The scripts return no data, or a very small potion of data compared to the snmpwalk command.
    -B
