Tags management
  • HeadQuaker
    • Jul 2015
    • 58
    Tags management
    I am suggestion three easy features to add to zabbix :
    1 - Tags DB : when the tags is news, add it in a table in the DB
    2 - Tags Manage : an easy way to delete, add, modify tags and their values in the DB
    3 - Tags Selecting : when adding a tags to an object, allow us to select them into a select box or auto suggest when typing in the field.
    Those 3 suggestions will remove an tags management out of zabbix and give to zabbix a new level of organization.
  • david598scott
    • Jan 2025
    Originally posted by HeadQuaker
    I am suggestion three easy features to add to zabbix : JoinPDcom
    Your suggestions for Zabbix are excellent and could greatly enhance its functionality:
    1. Tags DB: Integrate tags into a dedicated table in the database.
    2. Tags Manage: Simplify the process of deleting, adding, and modifying tags and their values.
    3. Tags Selecting: Implement a selection box or auto-suggest feature for adding tags to objects.
    These features would streamline tag management and bring a new level of organization to Zabbix.
    Best regards,
    David Scott
    • troffasky
      troffasky commented
      Hello, is that you, ChatGPT?
  • troffasky
    • Jul 2008
    • 639
    It's a bit disappointing that when you manually add tags to a host, there is no search of existing tags to assist you. Seems like an "obvious" feature that is missing.
    • HeadQuaker
      • Jul 2015
      • 58
      I hope my suggestion will be taken in account.
