Has anybody considered the idea of using a web service to send data to/from for remote agents? For example, a lot of people have their servers behind very restrictive servers, and allow outbound http(s). It'd be handy if a web service was available for agents to post data to.
Example of posting data:
You could also use a similar idea to find checks that need to be executed on the client to send back, and all the configurations can then be kept on the server end. For example, the client could post the following to the web service:
To which, the server could respond something like this:
What do you guys think?
<?xml ...?>
<zabbix>
<agent key="abc12" hostname="zabbixclientname" />
<items>
<item name="keyname" time="timestamp">valuehere</check>
<item name="keyname2" time="timestamp">othervalue</check>
</items>
</zabbix>
<?xml ...?> <zabbix> <agent key="abc123" hostname="zabbixclient" /> <command>getchecks</command> </zabbix>
<?xml ...?>
<zabbix>
<items>
<item name="keyname" frequency="60" type="character" />
<item name="keyname2" frequency="90" type="float" />
</items>
</zabbix>
