Graphs Time Intervals not showing, Text not rendered correctly SOLUTION.
  • Alexcr
    • Jan 2025
    The issue with the Text not rendered correctly on the x-axis is not due to the Zabbix version, the error lies in the version of the libgd3 library, specifically in version 2.3.3-12 and later.
    In my case i correct it in debian using apache2. For other flavors of Linux, check the appropriate instructions.
    Check the installed version
    dpkg -l | grep libgd3
    in my case: 2.3.3-12+b1 amd64 GD Graphics Library
    Check Available Versions
    apt policy libgd3
    In my case:
    libgd3:
    Installed: 2.3.3-12+b1
    Candidate: 2.3.3-12+b1
    Version table:
    *** 2.3.3-12+b1 500
    500 http://deb.debian.org/debian trixie/main amd64 Packages
    500 http://deb.debian.org/debian unstable/main amd64 Packages
    100 /var/lib/dpkg/status
    2.3.3-9 500
    500 http://ftp.de.debian.org/debian bookworm/main amd64 Packages
    2.3.0-2 500
    500 http://deb.debian.org/debian bullseye/main amd64 Packages
    Make the downgrade
    sudo apt install libgd3=2.3.3-9
    Then verify installed version
    libgd3:amd64 2.3.3-9 amd64 GD Graphics Library
    To prevent future automatic updates :
    sudo apt-mark hold libgd3
    Restart zabbix and apache:
    sudo systemctl restart zabbix-server
    sudo systemctl restart apache2
    This should fix the problem. Good luck.
    Let me know how it goes and include examples with Nginx and other versions of Linux.​
