Cisco HTTP SD-WAN Template Issue
  • Vame
    • Aug 2025
    We are getting on all devices we got from the HTTP SD-WAN integration template the following alarm that clear time to time:
    Cisco SD-WAN: There are errors in the 'Get device data' metric
    On the logs we have:
    [ Cisco SD-WAN ] ERROR: Failed to receive data: invalid response status code.
    We use SD-WAN version 20.12.3.1 and template version 7.2
    Looks like it´s not getting the correct information from the API or had some info that It couldn´t process.
    Is there anyone with or had the same issue?
    Thanks in advance
    • 5002
    Start with identifying, what status code it receives... I would guess, something about timeouts or auth errors or something... Script in that template throws that error, if it receives some other http response code but 200...
    • Vame
      Vame commented
      Is there any way to get the error from the script, is there any option for activating debugging?
    • 5002
    It writes to server log... you said "On the logs we see... " There should be more..
    Main item that does authentication contains script which logs codes also..
    Zabbix.log(4, '[ SD-WAN API ] [ ' + url + ' ] Received response with status code ' + request.getStatus() + ': ' + response);
