Log Monitoring help
  • n3o
    • Jun 2016
    • 27
    Log Monitoring help
    Hello all,
    I am monitoring a log file and whenever "no connection" appears it gets triggered and sends me an email but the issue is when it changes line in the file I get a recovery email and again when the word "no connection appears" I get an email and so on until the problem is fixed.
    an example of the log file:
    0 15:33:42.182 Datafeed: closed due close command
    0 15:33:42.182 Datafeed: waiting for 0 sec
    1 15:33:42.182 Datafeed: connecting to 'x.x.x.x'
    1 15:33:50.544 Datafeed: no connection to 'x.x.x.x' [I get an email]
    1 15:33:50.544 Datafeed: no connection to the server
    0 15:33:50.544 Datafeed: waiting for 0 sec [I get recovery]
    1 15:33:50.544 Datafeed: connecting to 'x.x.x.x'
    1 15:33:50.544 Datafeed: closed due timeout
    1 15:33:59.576 Datafeed: no connection to the server [I get an email]
    0 15:33:59.576 Datafeed: waiting for 0 sec [I get a recovery]
    1 15:33:59.576 Datafeed: connecting to 'x.x.x.x'
    Is there a way to avoid sending a recovery email when changing line and to send ONE email only when seeing the "no connection" words ?
    I have the below Key and Trigger:
    Key:
    logrt[Path\*.*,,,,skip,]
    Trigger:
    {Host:logrt[Path\*.*,,,,skip,].str(no connection )}=1
    Type:Zabbix Agent (active)
    Type Of Information: Character
  • n3o
    • Jun 2016
    • 27
    Someone suggested to use the below in my trigger:
    {Host:logrt[Path\*.*,,,,skip,].count(1m,"no connection ",like)}>0
    can someone explain what it does?
    • andresf
      • Jan 2017
      • 16
      Delete the default recovery action for that action. I think it should work for that ( on recovery "do nothing"). I thinkg you have to create a specific action for that kind of "trigger action".
      Tell us if it works.
