Nextcloud monitoring CPU leaks
  • AntonZubkoff
    • Oct 2025
    After install template for monitoring Nextcloud, Nextcloud servers "died". CPU load 100%. Hundred requests from Zabbix server to Nextcloud servers. Php-fpm use 100% CPU.
    HTML Code:
    10.100.6.254 - ncadmin [21/Oct/2025:01:25:23 +0300] "GET /ocs/v1.php/cloud/users/439D37DE-1A45-4EFB-A633-97553EFD9C67 HTTP/2.0" 200 562 "-" "-"
    10.100.6.254 - ncadmin [21/Oct/2025:01:25:23 +0300] "GET /ocs/v1.php/cloud/users/A524A6B2-B26A-45BD-9934-3FB6D373E3B7 HTTP/2.0" 200 569 "-" "-"
    10.100.6.254 - ncadmin [21/Oct/2025:01:25:23 +0300] "GET /ocs/v1.php/cloud/users/E67BDF1A-865E-4770-8F3D-46459EF739DB HTTP/2.0" 200 568 "-" "-"
    10.100.6.254 - ncadmin [21/Oct/2025:01:25:23 +0300] "GET /ocs/v1.php/cloud/users/7A4F668D-809B-4847-A62B-D1FBC0D9B0FD HTTP/2.0" 200 568 "-" "-"
    10.100.6.254 - ncadmin [21/Oct/2025:01:25:24 +0300] "GET /ocs/v1.php/cloud/users/9F8C8B6E-A748-4863-BC78-007932655F25 HTTP/2.0" 200 571 "-" "-"
    10.100.6.254 - ncadmin [21/Oct/2025:01:25:24 +0300] "GET /ocs/v1.php/cloud/users/761EFCA1-F29E-4475-862F-848EE47FB110 HTTP/2.0" 200 568 "-" "-"
    10.100.6.254 - ncadmin [21/Oct/2025:01:25:24 +0300] "GET /ocs/v1.php/cloud/users/9B1B7543-3F78-43E6-B8E1-BF6DEC2E34EA HTTP/2.0" 200 570 "-" "-"
Name:	Screenshot 2025-10-21 at 01.43.42.png
  • guntis_liepins
    • Oct 2025
    • 61
    Which zabbix version you are running?
    How many users do you have on Nextcloud instance?
    Are you using zabbix official template ?
    If you are using zabbix official template, what monitoring intervals do you have for "User "{#NEXTCLOUD.USER}": Get data" items ?
    • AntonZubkoff
      • Oct 2025
      1. 7.4.3
      2. 250
      3. Official
      4. 1h
      • susankeaton
        • Oct 2025
        to identify which processes are using the most CPU, especially during the time of the leak. Then, examine Next cloud and web server logs for errors, check your configuration, and consider issues like an excess of users, an undersized caching setup Op Manager is ahuman benchmark CPU usage monitoring software that enables CPU performance monitoring, CPU health check, CPU resource availability monitoring, CPU speed checks, and more. Op Manager is both a Linux and Windows CPU usage monitor console.. Task Manager's Performance tab shows detailed information about CPU usage. Older computers may not have the appropriate drivers for optimal performance. Updating these may fix the problem.
        • AntonZubkoff
          • Oct 2025
          Sometimes it's better to remain silent so as not to appear stupid...
