When we move from version 7.0.22 to 7.0.23 the Java Gateway stops being able to reach our RMI endpoints with errors similar to this:
We are using the based container images and the same happens if I switch from Alpine to Ubuntu. If I change the tag back to 7.0.22 the issue resolves itself leading me to suspect something change in 7.0.23 that I didn't see in the release notes. We are using a PKCS12 cert that is shared between the gateway and our endpoints. It's using a 2048-bit self-signed certificate.
Anyone else experiencing this?
compose file:
2026-02-11 12:52:28.490 [pool-2-thread-1] WARN com.zabbix.gateway.SocketProcessor - error processing request, item "jmx["java.lang:type=Threading","PeakThreadCount"]" failed: SSL peer shut down incorrectly: service:jmx:rmi:///jndi/rmi://server_name_here:1234/jmxrmi
compose file:
zabbix-java-gateway:
image: zabbix/zabbix-java-gateway:ubuntu-7.0-latest
container_name: zabbix-java-gateway
restart: unless-stopped
privileged: true
environment:
TZ: "America/Los_Angeles"
ZBX_PROPERTIES_FILE: /etc/zabbix/java-gateway.properties
volumes:
- /etc/localtime:/etc/localtime:ro
- /opt/zabbix/java-gateway/java-gateway.properties:/etc/zabbix/java-gateway.properties
- /opt/zabbix/java-gateway/jmx-truststore.p12:/etc/zabbix/jmx-truststore.p12
network_mode: host
depends_on:
- zabbix-db
- zabbix-server
