Kindly suggest and provide clarification
  • Abinash
    • May 2026
    • 11
    I am setting up an enterprise level project and want to use zabbix as monitoring tool.
    i am confused b/w 7.0 vs 7.4 , which version to use.
    I am using two servers for monitoring and using mariadb galera as a database and a galera arbitrator for quorum vote.
    I am using keepalived and rsync process.
    Kinldy suggest me any other information to make it more better and robust.
    Also is there any vulnerability or loop hole in the code of zabbix that can be a threat for an enterprise level, as i am new to the tool.
  • SanMonitor
    • Aug 2022
    • 49
    Hello Abinash,
    Version 7.0 is the LTS (long term support) version, whereas 7.4 is just the latest version. If you are planning to update the zabbix version regularly you can install 7.4 now. If you want to run the same verison for a longer time without needing to upgrade, the 7.0 LTS is a better choice. More information about the lifecycles you can find here > Zabbix Life Cycle and Release Policy
    To make your setup more secure you can have a look at these best practises, 1 Security best practices
    And current vulnerabilities you can find on this page: Zabbix Security Advisories
    Good luck setting up your system!
    Kind regards
    SanMonitor​​
