Editable inventory column names
  • Breorn
    • Dec 2017
    Hello. Is it possible to have editable column names in inventory? It should be based on template (you can create inventory template inside device template or chose inventory template, that You previously created, from menu). For example: We have a network printers, which are oversighted by Zabbix. We need to rename some columns to Counter total, Print counter, Fax counter, Used toner type etc... I think, that some other users found this usefull, don't You think? PS: Zabbix is the most powerfull opensource monitoring solution, that I used. Thank You so much for it.
  • troffasky
    • Jul 2008
    • 639
    No, you can't. If you want to be able to, you can vote for this venerable feature request here:
    • DmitryL
      • May 2016
      • 278
      You can check Inventory field names in frontend code, but that will be a global change for all hosts.
