zabbix maintenance window
  • rezwan
    • Jan 2018
    • 16
    Hi ,is there any option to integrate zabbix maintenance window with Microsoft outlook calendar,idea is when i will set new maintenance in zabbix it will automatically add a new calendar item in my outlook.
  • tcilmo
    • Nov 2016
    • 122
    No there is not. I honestly don't ever see that happening, but I have been wrong before.
    • kloczek
      • Jun 2006
      • 1771
      If you want to have maintenance window open/close notifications it is possible to create actions and you don't need to add new entries to the calendar.
      Configuration -> Actions -> first tab with Actions -> New condition -> Maintenance status -> in/not in -> then on Operations tab you can define email notification or execute remote command. On other tabs you may need to add other options.
      • rezwan
        • Jan 2018
        • 16
        Thanks a lot for this guide .can u share me any script for this solution
        • kloczek
          • Jun 2006
          • 1771
          No, I cannot because I have no such example
          What needs to be in such script really depends only on what do you want to do in such script. In simplest form as the remote command, you can just execute /bin/mail or /bin/mailx with the set of parameters taken from zabbix macros.
