Instance/Port level monitoring
  • tahir.bhatti
    • 56
    Hello All
    I want to monitor multiple instances of a machine. By multiple/different instances i mean that i have a Solaris machine and on that there r five different web servers having unique port are running and on each web server a single Java process is running. i want to menitor the CPU utilization and Memeoy utilization by each Java process. I can monitor the over all memory utilization by java processes but i want to monitor five jave processes separately. is there any solution possible.
    Thanks in Advance
  • Wolfgang
    • Apr 2005
    • 116
    You might want to implement your own user defined checks and run them through the zabbix_agentd.
    The default zabbix_agent.conf contains such samples for mysql.
    Regards
    Wolfgang
    http://www.intellitrend.de
    Specialised in monitoring large environments and Zabbix API programming.
