1.4 : Sensors
  • pymouse
    • May 2007
    • 19
    1.4 : Sensors
    I am on RHEL4, and i want to have information on temperature of CPU and MotherBoard, but sensor isn't supported...
    i see in source code (sensors.c) :
    dir=opendir("[B]/proc/sys/dev/sensors[/B]");
    	if(NULL == dir)
    		return SYSINFO_RET_FAIL;
    	while((entries=readdir(dir))!=NULL)
    		strscpy(filename,"[B]/proc/sys/dev/sensors/[/B]");
    		zbx_strlcat(filename,entries->d_name,MAX_STRING_LEN);
    		zbx_strlcat(filename,name,MAX_STRING_LEN);
    But with the kernel 2.6, the sensors interface has moved from /proc/sys/dev/sensors to /sys/bus/i2c
    It's normal ?
