Circular data & statistics?
  • maxlock
    • Mar 2005
    • 32
    Hiya,
    How about adding circular data & statistics capability. ie. a wind vanes direction can be anywhere between 0 to 360 degrees. 0 degrees and 360 degrees are identical angles, so that for example 180 degrees is not a sensible mean of 2 degrees and 358 degrees.
    This would be useful for me, for monitoring some weather data, are there any other uses that could be applied?
    -Cheers Max
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Are you thinking about new type of chart or special functions and special processing for data of this kind?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • maxlock
      • Mar 2005
      • 32
      Possibly, something like a rose diagram for the charting. Special functions would probably be an averaging function, max and minimum values wouldn't apply, that's about it I guess.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        It seems to be very specific requirement. Not sure if it ever be implemented without higher demand or a commercial support.
        Alexei Vladishev
        My Twitter
