Zabbix and gentoo
  • sauron
    • Jan 2005
    • 215
    #16
    Zabbix 1.1 included in portage tree.
    • Clansman
      • May 2006
      • 28
      #17
      Hi sauron;
      I've installed zabbix-agent-1.1-r1 and zabbix-server-1.1 on a gentoo server I'm working on and I've found out that it doesn't 'chown' some relevant directories like:
      /etc/zabbix
      /var/log/zabbix
      /var/run/zabbix
      A quick look around the ebuilds seems to indicate that thei're correct... at least that's what the section 'fowners' in src_install() seems to indicate.
      However, I've retried installing the packages and the same happens; the files and directories are owned by root:root.
      Any ideas?
      • sauron
        • Jan 2005
        • 215
        #18
        update portage
        • Clansman
          • May 2006
          • 28
          #19
          Originally posted by sauron
          update portage
          Are you suggesting that portage itself is not processing the ebuilds properly? What version would you suggest?
          • sauron
            • Jan 2005
            • 215
            #20
            I'm got this problem at old portage package (not tree) when i'm updated it problem dispared
            • Clansman
              • May 2006
              • 28
              #21
              I think the /etc/init.d/zabbix-agent/server could be further tuned to:
              start:
              1. if .pid file exists, check for another running instance of the agent; if none found, remove the file and start zabbix-agentd.
              2. if zabbix-agentd is unable to bind to it's port, wait a while and try again until some maximum timeout reached (squid does such upon shutdown).
              stop:
              3. after killing process, see if program really died. check for .pid file left behind and clean it if found.
              I'm suggesting this because zabbix-agent frequently chokes on itself. Sometimes /etc/init.d/zabbix-agent stop doesn't remove the .pid, sometimes the process doesn't start because the kernel hasn't let go of the port previously used...
              I could do this myself, but I'm not familiar with the gentoo-way of /etc/init.d scripts so maybe there are elegant ways to do this. However I could give it a shot and hand them over to you.
              What do you think about it?
              Cheers,
              • wschlich
                • May 2006
                zabbix-agentd is the one to fix, not the init script.
                • Alexei
                  Founder, CEO
                  • Sep 2004
                  • 5654
                  #23
                  The TIME_WAIT issue is already fixed in CVS. There is another thread which contains a patch for all interested in ZABBIX Forums.
                  Alexei Vladishev
                  New York | Tokyo | Riga
                  My Twitter
                  • Clansman
                    • May 2006
                    • 28
                    #24
                    heh, thanks alexei.
                    welcome back to the less-fun-than-wedding-hollidays life.
