images and maps
  • dsipe
    • Oct 2006
    • 184
    images and maps
    after spending time on creating map with zabbix, I propose to change the image creation screen :
    1) first field : image name ( example: Linux Server )
    2) second filed : image for on status
    3) third field : image for off status
    4) fourth field : image for unknown status
    Then, when creating a map, and adding an element on it, we just have to give the image name.
    The right image to display (on,off,unknown) we 'll be automatically retrieve from the corresponding field.
    This will give just ONE point of modification for all the maps.
    Hope anyoneelse interested!
  • qix
    • Oct 2006
    • 423
    Sounds very nice.
    Most of the time we will use the same images for all the servers anyway (in fail state).
    Perhaps an other way to implement this is via the templates?
    You could then set the images for the "Windows server template" which would then be used in all screens with windows servers based on that template.
    With kind regards,
    Raymond
